Please suggest a good bandwidth monitor freeware for WinXP. I want to know my usage, now that I have applied for MTNL Triband.
Ideally, it should autostart with Windows, detect when a network connection is established, show download-upload statistics (seperately as well as total) for each session and also total ever since installation/first usage with time-date logs. There are so many bandwidth tools floating around, its really hard to try each and find the best so hoping to tap the experience of other users. Thanks in advance.
NETSTAT - freeware… get it from…
DUMETER
Is DU Meter freeware ?
trial for 30 days i think..
trial… is it??
ohh ya no more!!
NETSTAT … is F-R-E-E ![]()
Something which tells me statistics for every hour please, I want to seperate my free download usage (0000-0800) from the paid usage
Try Bandwidth Monitor Pro…its quite good
Its a 30 day trial…but after 30 days it shows a small tab saying click ok if u want to continue using the software illegally…
Why not pick a monitoring software and start it only when you go on line with the paid download usage conx. This way you will have a record of this Internet accounts usage.
What I do is use OnlineEye for my MTNL conx and DU Meter for my Cable conx. I have bought both these programs.
Here’s one you might want to look at. They also have a freeware version.
