Hope mobile is not a strict requirement because MATX is not small enough to be mobile. But if you’re fine with that then Lian Li A3 is a good choice. For anything smaller than that you will need to go with an ITX motherboard and SFX PSU which will cost quite a bit more.
matx really doesn’t do justice for mobile pc cases, so I’d advise on going itx. There is someone here who deals on itx boards and cases at reasonable prices. I think you can get them on his site. You’ll only need to change the psu to an sff version and maybe drop the hdd too depending on the itx case.
Mobile isn’t a priority, I just might move it within my house once or twice every 6 months. I can change the mobo, but not willing to change the PSU or cooler
The mention cases are just for reference. I was hoping to hear some other suggestions that you guys might feel are better. In essence, I want a case (Max height/length of 450 mm) that can accommodate my current system without changes (ideally) or with a change in mobo at the most.
On further inspection, you might want to go for the lancool 207, the gpu slot is 375mm while the gamemax has 355mm which is a bit tight for your gpu (i think 350mm, from your pic)
You won’t need to make any changes to your current system with either, both have mount/slot for hdd too, depends on how much space you want for your gpu.
Look at Ncase M2, case is a bit pricey, and unfortunately the specs for ATX PSU (160mm length max) and CPU cooler height (145mm max) are both below your existing components. But you could look at selling your components and getting the compatible ones for relatively cheap as there is no ITX tax on these.
Drop the H6 flow or any H series case. I dont know why people dont realise that it has no dust filters and the front mesh is not enough. Not enought for indian conditions with or without air conditioned room.
The most compact ATX case that is available right now is probably Lancool 207. Do not forget to buy an optional dust filter. Buy that case only if the filter is also available to purchase. Many times it goes out of stock so dont buy the case unless the optional filter is available. But this is not an option for you because of the PSU you have. You have plus size ATX PSU and some of these compact cases and compact mATX cases will not fit 180mm PSU.
The C5 and GT502 will but mind you these are not compact cases, The desk footprint is big for these. Height is low but not the desk footprint.
There is Lancool 217 but its not really compact. but it is smaller than your current setup by some margin.
If not these you can opt for one of your selected options. Anything but H6
But do keep in mind the Panoramic cases are not ideal air-cooled cases. The turbulence created by bottom and side fans is not something the front-to-back oriented air coolers like, and those end up running a little hotter than cases with conventional airflow.
Alternatively, instead of changing the board, you can sell the PSU and get a smaller PSU and that will open up the Lancool 207 option.
I am more confused now than ever. Can anyone suggest a Mid-tower that is smaller/lighter than the current case; ideally maximum height of 450 mm (no restriction in length or depth) and can house my current hardware without any exclusion/replacement. The purpose is a mix of AAA gaming and regular PC usage/office productivity. Budget is upto 20k
