I had regular 207. The only difference is screen on digital. The rest is identical. As I mentioned, your existing PSU will not fit in it. Otherwise its great case. Compact for a mid tower, great airflow.
Just buy it right now if you are zeroing in on 207. The filter is not included unlike 217 where it comes with the case.
Its a must. Other than that, nothing else out there matches the cooling potential of this case.
But as I mentioned your PSU will not fit due to the way PSU is mounted at the front of the case sideways. If you are selling yorus and getting one of the newer more compact PSUs, then its a great option.
I have few different setups which I had in this case. Will post some pics.
If you have any speicific questions about the built or compatibility, you can tag me. I have built 3-4 different systems with this case. Both air-cooled and AIO cooled.
I love the 3-chember concept, and this cabinet can accommodate any new builds in the future.
Although no one suggested this chassis, but all the suggestions helped me narrow-down what mattered to me more, and the limitations to consider while choosing the new case. Thanks for that!
Network: Intel Wireless-AC 9260 160MHz + Intel I211AT Copper (Pearsonville) Network Adapter OS: Microsoft Windows 11 Professional (x64)
Purpose is 4K 60fps gaming (Single Player games mostly story-driven AAA and sports titles). So, the questions is, do I need any upgrade till AM6 components arrive in 2027-28. I hope not.
Cannot really call it compact in terms of width but definitely lower in height and length compared to my Cooler Master MasterCase H500. It is still on the way so cannot share photos of the actual case. But if you see the photo below, I can now fit my PC up on the table:
Please do post photo once you get the case and build on it , I had added this to the cart in amazon , and visited local shop to see if this was a good option , none of them had this in display. And from YouTube videos was not able to arrive at a decision.
BTW wher did you get it from ? How much did it cost ?
Sure, will do. I got it from Vedant, and usually they send it same day or next since Iām in Kolkata, but this they are taking longer, they may havenāt had this in stock but was listed on their website for some reason. Black one is easily available. This cost me 18k ish
While the white buildās cabinet, AIO and fans are stocked for 2028 ā¦
Here is the revamped current build with new cabinet, additional 32GB DDR4 RAM with matched frequency & CAS, brand new AIO
Added:
Thermaltake View 380 TG ARGB Mid Tower Chassis Matcha Green
Mini ITX build is an expensive affair and has limitations of what all can be added. I wouldnāt have been able to add this kind of LCD AIO on an ITX. So different priorities, not beating one another. Hence, for me, my current mid-tower fish tank build beats any ITX build
Yeah⦠generally compact builds and LCD aio are choices of 2 completely different people⦠but that can overlapā¦
What I am talking about is MATX motherboard and AtX psu⦠I had those in my NR200, now replaced the PSU.. but motherboard is still MATX⦠A3 supports MATX mobo and ATX PSU⦠so no ITX toll⦠but yes it has limited compatibility⦠there are some pros and cons of each setupā¦
Agreed. I made the Thermaltake Green build just for 2-3 years. After that Iāll be using the Corsair AIR 5400 triple chamber case for AM5 build, perhaps better to wait for AM6.
I rushed to buy the Corsair cabinet and AIO, and now sitting idle with me till the market for complete new PC build becomes viable. Maybe Iāll ask if anyoneās interested to buy at a discount.
