Bajaja Media Table Fan relatively less noisy compare with Orient
Guys I’ve found the fan. Bajaj Midea BP-07.
Pedestal- 2599rs.
https://www.amazon.in/dp/B07P4G9211/
Table fan- 1899rs. Amazon.in
I don’t know about the Orient but the Midea noise level is so much better than my Havels. I went to a relative’s place and they had a Bajaj pedestal fan. I checked the model and its the same one which you mentioned.
But how did you know about the noise levels of the fans? Have you owned both?
I bought Bajaj Midea BP-07 Rs.1800/- from Local Shop in 2017.. you need to check same with offline shops.
Recenetly visit local electrical shop for some switch/socket etc. and found various products way cheaper or low price with offline market.
