The Sony Vaio CB15 Review
I get a doubt in mind when i see these gaming lappies. why dont the lappies with a good GFX card never match their correspondind sibling on the desktops.not even 50% of the performance too i suppose. like 9800M cannot match 9800(desktop version).
^^ I guess mobile GPUs are numbered differently, that’s all.
@OP: gah how can i help, i dont have experience with this dual-gpu stuff at all :grinning_face_with_smiling_eyes: but lets see how it goes…
Here is a detailed post on ATI switchable + Linux
Envy 14 & Linux
Can you compare this laptop to the Dell XPS 15 (L502x)?
What are the major differences? Which one is better?
What are the problems that you faced with the CB15?
Is the GPU switching smooth enough?
Do the glossy surfaces act like a finger-print magnet?
Can you put up a summary of your review (pros/cons)?
thanks in advance!
sorry diggin a old thread,op are you still active?
but i am really looking forward to buy either this or a hp dv6…
1,does it overheat while gaming(hp does)
2,how is the gaming performance with 6630?
3,any other problems you faced with laptop?
1.)no overheating issues noticed. According to me, this one has very well placed vents, plus i have assigned a direct kb shortcut for fan speed(its provided in sony drivers), so i set the fan to “performance mode” when gaming, and this baby stays cool
2.)runs not-so-demanding games quite well i must say. Played portal2 at 1600*900, 2xmsAA and some settings high, some medium, and the game runs like maska.
Mafia 2, though give just around 23fps.
3.)no problem faced yet, but i would’ve appreciated a little metal on the laptop body…its all plastic now, but its strong plastic nonetheless.
hows the quality of 720p webcam …my friend is having issues with his cam?
@op i went to a sony dealer(authorised) and he said the price to be 54k…
did you buy from any other dealer??
No i dint go to a sony exclusive dealer.I am in Mumbai…so went to a lamington rd. shop which deals mainly in laptops and ordered..because you have a better chance of bargaining there.
Btw the dealers get the laptop for around 52.7k so whatever extra u pay is their profit.
Do you think thats true? :rofl:
I too got got it off Chandni Chowk, Kolkata @ 52.9k. Had to show them Flipkart price & bargain twice. Sony Center quoted a fixed price of INR 54990.
What memory module would be compatible with the installed 4 GB memory ? Can I pick it out online somewhere ?
Any module should work but check the timings first. My laptop came with a Samsung module installed.
CB15 owners - how to do a clean install of Win7?
Hello CB series owner, i just puchased this master peice on 17th July from jumbo Electronics. I m truely enjoying the glossy black color body, backlit keyboard are real blessing for my kind of user :slight_smile: Though i very new to Win7. Can somebody here (expert) can advise me 2 things-
1-How to add additional drives, i mean my C: drive as of now has 410 GB of space, i want to add atleast 2 drive or more (as D: & E:) can you help a bit in prcoces.
2- I m constantaly getting notification for -Windows Update are ready to install"- do you suggest to install and update windows everyday or everytime when i get this message ? last i rememver i got 3 important updates available to install message while installing it didn;t installed , throwed some error.. i couldn’t feel like investigating this as this not hampering my work either way.
Suggestions/modifications are deeply welcomed.
Thanks
Just download Genuine Win7 HP 64-bit from Microsoft for free. Google for Win7 Digital River. Its 100% legal if you use the product key that came with your laptop.
Burn a bootable disk using vLite. Clean format using it.
Install all drivers from here, except VAIO Gate, Location Utility & Quick Web Access if you don’t need them.
Right-click Computer. Select Manage. From left panel, select Disk Management. Right click the C: drive in the right & select Shrink Volume. Shrink it to your preferred size. Then create new volumes from the free space you created.
How are the vertical viewing angles on this ? I got a xps 15z which I had to return due to some damage, and its out of stock till mid august. Other option is regular xps 15. interested in something that has a FHD display and half decent viewing angles
Thanks Mate for this information. Is there any normal standard breakup of 500GB HDD else we may create as many drive as we can depending upon size allocation.
what about updates? is it recommended to install those updates? i havent felt any great use of that.
I have got MS Security essential Anti Virus free subsrciption for 3 years :slight_smile: thinking whether its good enough to secure my daily downloads from diff web site or should i move to McFe or Norton.. any advise guys.
