I’m selling VGuard VCB14-F030 Automatic Water Pressure Pump (Inline Circulation Pump). I bought it in 2021 because of low water pressure at home, and I needed better pressure for a new washing machine. I ended up not using it mostly because I was just lazy. It has been lying unused in my house since then.
The pump comes with all original accessories including the box, manual, warranty booklet, and various fixtures and fittings. I only ran it once to test it, and that’s it.
It weighs around 3 kgs. Very useful for washing machines, geysers, and any setup that needs better water pressure.
It might. If your house has poor water pressure, it will take time for the greaser to fill up with water and thus won’t be able to heat water effectively, especially if you are also draining hot water. This will help in pumping water faster in to the greaser which will for sure increase life of greaser, pump more water in and also save electricity.
I don’t have that issue. It’s the other way around. Inlet pressure is fine. Outlet pressure is not. And I bought a brand new geyser lately so don’t know what’s at fault here
This will definitely work with the geyser. I have been using pressure pump since 2019 as at first I had a Bosch WM which had problems with water pressure. Bought a pressure pump to solve WM issue but after changing my WM to LG I did not face water pressure issue and since then have been using the pressure pump with geyser, shower and for other water outlets. If you are not able to connect the geyser with the pressure pump please take the help of a plumber. Also this water pump should be 0.5 HP. It will definitely work with geyser. The seller has also priced it very well.
