Can anyone tell me where I can get refills for my TT Aquarius II liquid coolin system? If not, what are my options???
refills?
You mean that small green colour liquid that you mix with water?
Well that liquid is nothing but the coolant concentrate. Get some distilled battary water, and also buy some coolant from car shop. Mix them and use it. Works like charm ![]()
ohh dont forget to add few drops of savlon in it, prevents algae from growing inside your aquarious II ![]()
You can also get Pre-Mixed Ultraviolet Reactive Coolants. These look great. They cost only $5-10. dont know if you get them here
Hey naga, though i may not be of much help in this topic, can u tell me how much u bought tht watercooling system for?
7 k near abouts.6 months back.
