For office calls, the best option is wireless with boom mic. Unfortunately they all get pretty pricey.
As for TWSs , I have tried plenty.
Most have really poor SnR ratio and tend to attenuate your voice as well under even minimal background noise.
Of the lot I have tried, AirPods and pixel buds A have been on the better side though none will come close to a boom headsets
Mi basic bluetooth earphones, I own a lot of devices but these have the most superior mic quality plus it can be connected with 2 devices simultaneously. Lasts for good 8-9h in one charge.
if you are looking for cheap
https://www.amazon.in/Techspark-Over-Ear-Headphones-Adjustable-Pairing/dp/B08P1VC441/ref=psdc_1388921031_t4_B081D7CD5K
https://www.amazon.in/Zebronics-Zeb-Envy-Bluetooth-Headphone-Detachable/dp/B07X8PHTZ7/ref=psdc_1388921031_t1_B08P1VC441
https://www.amazon.in/LOGIC-Professional-Bluetooth-Headset-Compatible/dp/B09M45CD82/ref=sr_1_9?crid=34UWFNNE3ON0Z&keywords=bluetooth+communication+headset&qid=1640952004&sprefix=bluetooth+communication+headse%2Caps%2C256&sr=8-9
Price seems ok but never heard of these.
If you are looking for something tried and tested, Poly Voyager UC seems to be the cheapest
Saar you are a lifesaver. bought one of these and my jabra is working nicely on the adapter. And an added plus is that it when i am listening to music, i get the full clarity, and when I am using teams, i get two way comms - something you need to switch manually in windows between headset and headphone profile ! 6 stars is not enough for this
Where did you buy it from/ Hows the experience been with it? I am planning to buy it (now Epos PC8) from headphonezone. Does it still work fine? Any issues with warranty
I posted that in 2021. Bought from [Amazon](’
The volume knob is showing its age. Using the knob mutes the headphone completely. The ear muffs wear off every 9-12 months.
Other than above issues, it works well, no complaints.
thank you so much. are the ear muffs changeable? if so, which ones do you buy
I alternate between Sony WH-1000XM4 and Jabra Elite Active 75t. I use Jabra for casual calls or when listening music but XM4s exclusively for serious meetings.
XM4s are supposed to used for more than that ![]()
using company provided Logitech h650, audio quality and comfort is very good, i don’t know if it’s teams or headset doing the work but background noise filtering is very very good, nothing can be heard from otherside except your voice.
I bought these. Been a year, they are yet to show any signs of wear.
Crysendo Crystal 3 Pairs of Sponge Headphone Cover for All Earphones (55 mm , Black)
I am trying to prolong their life (albeit notionally) by using them only for important stuff. ![]()
Post this setup, I tried various combinations/headsets, before settling with [Go Work](’
JLab GO Work Wireless On-Ear Headset 2nd Gen’
) headset from JLab.
Using it for an year now and really very happy with the microphone performance/isolation.
What appeals to me the most are the multi-pairing capability, great wireless range, high quality boom mic, a physical mute button & an LED indicator towards the end of boom mic.
The led indicator show up in your peripheral vision, so it’s easier to see if the mic is muted/unmuted.
It also comes with a 3.5 to type-c cable, so that it can be used as a wired headset too if required.
The only grouse was that they didn’t bundle a case, so I ended up getting this sturdy case from Amazon, which fits like a glove.
Rekindling this thread. Not looking for a suggestion but to just engage conversion if things have changed from what we last discussed 2 years back.
I recently know of a colleague in office (other city) using Bose N700 headphones and its noise isolation is very good it seems and quality of mic too. When he is on call with us, it is very good, almost seems like he is in an isolated room but he is infact in an office with sounds from all side.
I would love to have such earphones in neckband form or so.
Rocking XM5, Bose QC 45 & Nothing Headphone 1 for a while. Randomly for work related and casual stuff. Tweaked heavily their EQ. Decent ANC and sound quality for the price. All got less than 20K each.
