Where's my USB??
Hey,ppl
Iam new here and would appriciate ur help.Well my Motherboard-MSI KT4V does have 6 usb ports whch use to function properly bfore,but when after lng time i tried to connect my USB device to the port my device was not detected.I check in device manager utility and it didnt have my USB ports or connct. listed,i use windows xp(sp1), i used a usb utility to troubleshoot ,it showed the following message:-This version of Windows supports USB.
This system has hardware that does not support USB.
This system must also have at least one physical USB port where a USB device can be plugged in.
Wht can possibly be the prob ?
Reply asap and thank u fr u r tme.
check in the device manager whether the usb controller or anything that says usb is enabled or not.
I guess Device manager has everything…u got to check that
Hey ppl,
Thanks fr replyin,My device manager dont show any USB controller or anything,…
Iam attachin a image.
check if usb is enabled in the bios
yeah that must be the prob.. after you enable it from BIOS there will appear an entry for the UniversalSerialBus below system devices.
i have the same mobo… this happens if u reset bios battery…
enable it in bios and it will work…
