I have the 8.7 Inch RedMi Pad SE tablet. This has FM radio as well and it works when wired earphones are connected and I can also play it through speaker (but wired earphones are needed as they act as antenna).
Can anyone tell me if I buy a 3.5mm Jack antenna and connect to the tablet and extend it, will I get good FM Reception (inside the flat)?
Is yes, where can i buy cheapest one? Is there some DIY thing possible?
If you just need it to work as an antenna and you can play the radio via the speaker then just cut the speaker part off some old pair of earphones, ofcource do remember to tape the bare wire although they have coating but still safe to do it. Else if you need a ridgit antenna the buy something like this- aux antenna
