Will CS:S run on Geforce 2
Hey guyz , this may sound a bit crazy but i really need to know if CS :confused: ource will work on an onboard geforce 2 Gfx card with 1800+ XP AMD and 256 RAM.
I need to know if we tweak enough can u get playable fps on the above system???
And also how will it run on 2400+ XP ,geforce 4 MX onboard with 512 RAM ???
Thnx in advance.
It will run on them, in dx7 mode :slight_smile:
ya itll work. u will get aroud 50 - 60fps.
but in d2 n tec the fps will be 25 - 30
