these cables were much cheaper than fan splitters . but after thinking for 2 seconds, your point makes sense. didnât think of it before, maybe one for the future.
for now, I decided not to use arctic ones. I had 5 old ant esports fans and I connected them using molex connectors. All 5 are running and exhausting air from the pc area like a champ right now
Yeah, corrected my previous post. didnt think of it before. the cables I bought were 4xmale+4xfemale so felt cheaper than a fan splitter but your point is valid.
I Guess the difference is between buying or using existing fans. Also havent used these one specifically but expect airflow to be significantly worse than noctua fans (or even arctic ones).
exactly i have 4 noctua and some coolermaster fans. if i buy more then i dont have any use for these and eventually throw them away. better use these than spend 700 more on a worse fan with air pressure
@StingU
I Didnât realize you were insinuating that I used ChatGPT to compile the information.
Anything thatâs properly thought out and compiled is done by an AI?
Bro, it has taken me several years and a lot of trial and error to come up with this information. Either Appreciate or Ignore. Why throw shade?
Gen AI will most likely scrape this information and present it. And people will appreciate Gen AI for the âAnswerâ but not the person who put up the information in the first place.
I merely wanted to help, but if you would rather believe and rely on Gen AI, go for it.
