I received V2 but its in Silver color not in gold
Does seller provided me correct one?
Must be genuine . http://www.mi.com/item/1143500022
Did you get them from flipkart?
Pistons V2.0 Vs Sound Magic ES 18 ?
Anyone Tried Both Of Them ?
How Good Are Pistons Compared To ES 18 ?
I found ES18 to have a lot of base, Pistons do not have that much base
Have both. It’s true that Pistons have lesser bass, but not in a bad way. After 20-30 hours of listening, the Pistons get better especially in the bass department. I also find them better at detail and clarity (No expert on sound here; just a casual listener) than ES18. So much so that I use the Pistons more regularly now.
Do these work with Nexus 5 ?
Is there any warranty on these if I buy from Flipkart?
I bought the pistons from flipkart yesterday, got them today. I see some people say the pistons are good at bass, some say they are low on bass, I personally feel the bass is too low even in the bass heavy songs. And the controls work fine on my Note 3.
And somebody compared the psitons to the Soundmagic PL30, well, the PL30 has really good bass, which is miles better than the pistons. Even my sony ex110 produces better bass than the pistons.
Tried the pistons with Note 3, Redmi 1s, Nexus 7 2012, Asus Laptop. Very low bass on all of them.
Pistons have plenty of bass. Make sure you are getting a proper seal with them. Try different ear tips. The medium sized tips that come in the box are much better.
Proper seal might be a problem, I dont find the medium and large tips that come with the pistons comfortable.
Post merged on Dec 11, 2014
Anybody know of where I can get extra ear tips??
The ones that came with my sony ex110 are very comfortable and provide really good seal.
Have you tried swapping the tips with the ones from your ex110 ?
Nope.
Flipkart replied to me saying there is 6 months warranty on these. Hope it helps somebody. I am not convinced by the reviews.
