PC Peripherals 16x DvD writer showing 8x as max speed
You either need to update your DVD-RW's firmware or your DVD media is not compatible with the the DVD writer for burning in 16x mode.
hi kris rahul here ,you should upgrade firmware thats avaliable on rashi peripherals site rptechindia.com .If you got it from nehru place and do get good moserbare 16X compatible media (difficult to get ) and then try your problem should be solved and try nero or sonique to test :hap2:
