1st build - Done. Second incoming
abhijeet.xin
Enclave Plus
Beginner
Build https://pcpartpicker.com/list/tsb7z6
Added 6 X Lian Li UNI Fan TL 140 Reverse fans, used Noctua iPPC 3000 RPM (although those are monster) for a month but later realised this rig is sitting right in front of my face and I need something silent.
Where did you buy the Lian Li fans from? Did you face any issues with the Lconnect software? I'm also planning to buy the same set.
no issues with LConnect. I have setup fan curve in that and it works really well. Different speeds for front intake. Have two fans on top, one spins slower than the other to avoid pulling air that was supposed to go towards CPU fan.
