35k, parts needed !
Aman27deep
Hello peeps, please help me out here,
Q: What is your budget?
30 + 5 k
| Intel C2D E7500 | GA-G31M-S2L | BenQ E2200 HD | Palit GTX 460 Sonic Platinum | Corsair 2 GB 800MHz | 160 + 500 GB | MX 518 | Corsair VX 550w | xbox 360 controller |
Monitor - BenQ E2200HD
SMPS - Corsair VX550
GFX Card - Palit 460 GTX
Hard Disc - the 500 GB HDD from my rig
(please mention the rest in above format)
CPU - Has to be Intel, no AMD, i5 750/760 most probably ?
CPU Cooler - Please suggest.
Motherboard - any compatible motherboard
HDD - 1 TB seagate?
RAM - Please suggest
ODD - Please Suggest
Cabinet (have 5k aside for this, so total 35k) - Got some suggestions from here (http://www.techenclave.com/pc-peripherals/which-dust-free-cabinet-to-get-172206.html), If you want to help please do so too.
If i add something it'll just be another Hard Disc (if in the next 7 months).
Chandni, Kolkata, Local Purchase only
No, as probably Dad will go in for a 3 or a 6 month EMI.
Gaming
Browsing
HTPC
Download rig, 24x7 operation
Watching HD movies
Asus and Transcend products' might be good, but i dont want them under any circumstance cause of the A.S.S.
Every past, present and future game released, or to be released.
Gaming - 1980*1080
Desktop - 1980*1080
Yes
Windows 7 64 bit
Thanks, gonna buy this Saturday if things go right, please help ;')
WingZero said:
then get the ripjaws
cm 690 II is around 5.5k iirc
Hmm okay, then i'll get the GSkill ones, btw just out of curiosity, is there some Corsair RAM equivalent ? Also does this mobo (gigabyte p55-ud3r) have USB 3.0 ?
BTW what about the CPU cooler?
How much Do u intend to oc?...you cannot fit a cooler in budget else you can buy an nzxt gamma and then get a decent cooler.
For usb3 and sata3 you can get the p55A-ud3r actually i was gonna quote same:p
Well i wasn't gonna OC like hell, but yeah 25% if i get the 750, and 20% if i get the 760 :p And yeah okay that mobo it is then, thank god it doesn't have sata 6 gb/s, its uber useless as of now...
For that kinda oc i think you are good with stock cooling. Later on add a cooler if needed or restrict ur oc till then.
