80K Build NEEDS HELP
Need a new PC config PLZ
Budget - 80K
Product in mind
MSI X58 Pro-E
SAPPHIRE HD5850 1GB GDDR5
PSU HX650W
G Skill Tri Channel 6GB
WD 1TB SATA 7200
Cooler Master CM 690 plus II Advanced Case
Logitech MX 518 Optical Gaming Mouse
Corsair HX650W Profe.Power Supply
PLZ SUGGEST
1) Intel Core i7 (plz suggest which one me thinking of the 930 but plz suggest guys)
2) Monitor
3) Mouse Pad
4) Optical Drive
5) Keyboard
Also wanted to know if HSF is need with out overclocking or will it be fine
planning it on overclocking it later
ANY SUGGESTIONS ARE MOST WELCOMED
AND Also i would replace it with the tv in my room because of lack of space so do u think TV tuner is a good substitute
MSI X58 Pro-E~10.4k
SAPPHIRE HD5850 1GB GDDR5~15.8k
G Skill Tri Channel 6GB~9.6k
WD 1TB SATA 7200~Get a Seagate one for 3.3k
Cooler Master CM 690 plus II Advanced Case~5.5k
Logitech MX 518 Optical Gaming Mouse~1.5k
Corsair HX650W Profe.Power Supply~7.5k(Non modular TX650 costs ~6.4k)
Total: ~53.6k
Intel Core i7 (plz suggest which one me thinking of the 930 but plz suggest guys) ~ 14.2k Go for the i-7 930.
2) Monitor ~ Benq G2420HD ~ 10.8k
3) Mouse Pad ~ RantoPad H3 ~ 0.6k
4) Optical Drive ~ LG OEM GH22NS50~1k
5) Keyboard ~ Microsoft Comfort Curve 2000 ~ 1k
Total: 27.6k
Grand Total: ~81.2k
Get a good after market cooler when u O.C the proccy like the Noctua NH-U12P SE2 120mm SSO~3.8k
If ur comp is mainly for gaming... alternate build...
AMD 965BE + Gigabyte Crossfire mobo saves 8k
4Gb ddr3 1600MHZ dual channel corsair or g-skill saves 3k
Get the 5870 either stock or Toxic
Get noctua NH-D14 best aircooler on the market and oc to 4.2-4.4Ghz since u like ocing
Get a bigger 27 or 30inch monitor as u are replacing ur tv wit it
Get the Haf 922 to fit tht beast of a cooler... i think it fits in cm-690 as well... ur choice...
Change hdd to 2tb as u can never have enough space..
THink should still fit into ur budget and would be awesome for gaming as well as movies/ watching tv :D
