Budget 51-70k Advice for Audio Processing and Programming Rig.
VINA
Recruit
What is your budget?
50K to 70k
What is your existing hardware configuration
Monitor - 23inch LG
Which hardware component are you looking to buy
CPU
MOTHER BOARD
RAM
POWER SUPPLY
CABINET
SSD
No GPU At present
Is this going to be your final configuration or you would be adding/upgrading a component in near future. If yes then please mention when and which component
Yes, will upgrade the following within 6 months
GPU basic
Where will you buy this hardware? (Online/City/TE Dealer)
Ahmedabad
Open to online purchase
Yes
hat is your intended use for this PC/hardware
Browsing
Desktop Processing
Audio Processing
Operating System
Windows 11
