FS: Power Cooling and Modding Almost complete water cooling kit and control board
mav2000
Veteran
Feedback: 57 / 0 / 0
Bangalore
3 out of 5
  1. Cash
  2. Bank Transfer
Excluded - at actuals
None
No
Not using it anymore
Hi Guys,
For sale is a almost complete water cooling kit, for Intel and AMD systems. You will have to check if the CPU block will fit on current gen systems, as I dont know if the socket areas have changed significantly over the years. I have used this kit on both Z&&/87 boards and AMD AM3 boards. Everything for sale is well used and will have to be cleaned out properly before resuing.
1. XSPC RayStorm Pure copper block, with mounting hardware for Intel and AMD. https://www.amazon.com/XSPC-Raystorm-Block-Intel-Socket/dp/B005T01B54 costs about 50 USD
This would probably needs to be properly lapped down before using.
2. OC Cool D50 pump, with speed control and after market top - https://www.frozencpu.com/products/...ng_-_Single_Edition_Sata.html?tl=g30c107s1802
Same pump, but with a pump top, costs about 90 USD + pump top
3. XSPC AX 480 rad - 4x120 radiator, in very good condition. https://www.performance-pcs.com/wat...-quad-fan-radiator-black-xspc-ax480-bk-d.html Costs about USD 100
4. Alphacool heatmaster - Used for controlling all pumps, fans, flow sensors and temp sensors. Will be adding one temp sensor with this. Its completely programable and you can add your own setup. Will come with USB cable to connect it to your system. https://www.hardwareluxx.de/communi...st-der-aquaero-kein-elektronikschrott.628694/
Link is in german, but it gives you a complete breakdown of how to use this. Lovely system, once setup. Should cost around 50 USD
5. Koolance quick disconnects these are usually about 20 USD per set. 3 sets in total.
6. Bitspower and other fittings...a whole lot of them as seen in the pics below. There are 90 degree fittings, plugs, 4 way and 5 way splitters etc. I dont even know how to put a cost on this. The compression fittings are for 3/8" by 5/8" size tubing. Lots of extras as well.
All put together at cost this kit would cost 450 to 500 USD when bought new, not to mention costs of shipping and customs if any. I want to sell the whole thing as a set. All someone would need is good quality tubing and a reservoir. I am Open to trades as well and willing to negotiate. So dont hesitate to ping me and we will work something out.
mav2000
Veteran
Bump...open to negotiations...need this gone.
BTW, willing to sell in parts. Please PM if you are interested in any of the parts
apurva512
Feedback: 8 / 0 / 0
Hi, am interested in the quick disconnect fittings and possibly the rad. Are they compatible with soft tubing? Also, can you post better pictures of the radiator?
mav2000
Veteran
Everything is packed up as of now, but rest assured its in perfect condition. If you would like any specific pics let me know. Also, yes the QD's are for soft tubing.
