Slayer88
Hi any of you guys using the x53 aio? I'm curious to know your pump speeds. My pump seems to run at 2k+ rpm all the time. In CAM, whatever I set the pump profile to, it does not change a whole lot. I have set it to 'silent' but its still like 2200 and while gaming its going to 2600. In the bios its set to 'normal' and linked to the CPU temp.
Any ideas? I've got a 5800x which idles at 37-38c.
NZXT site says pump is from 800rpm+, shouldn't the pump be closer to that when the CPU is at 37c?
X52 users may also chime in.
TIA.
TIA.
