bssunilreddy
Hello
Want to know the budget ARGB Fan Hub or Controller
Please suggest
Budget is 1.5k or even less
Please suggest
how many fans u want to connect to ? china ka maal is for around ₹800 or so. I have a argb hub which i got from FB from sahil it 10 pin argb. you can also get a argb pin + pwd pin hub for some other configuration. connect with himHello
Please suggest
Okay will ask himhow many fans u want to connect to ? china ka maal is for around ₹800 or so. I have a argb hub which i got from FB from sahil it 10 pin argb. you can also get a argb pin + pwd pin hub for some other configuration. connect with him
Just sent PM check onceCome pm, I have an extra 8+8argb controller hub for very good price.
What do you use to control the lighting and fan speed for the devices connected to this hub?how many fans u want to connect to ? china ka maal is for around ₹800 or so. I have a argb hub which i got from FB from sahil it 10 pin argb. you can also get a argb pin + pwd pin hub for some other configuration. connect with him
He means both it seems as he mentioned argb fan hub.What do you use to control the lighting and fan speed for the devices connected to this hub?
MotherboardWhat do you use to control the lighting and fan speed for the devices connected to this hub?
What motherboard? I have an Asus one and armoury crate is just so useless. What’s your hub setup like?Motherboard
yeah ik I have the same hubHe means both it seems as he mentioned argb fan hub.
