Teknoklutz
Recruit
Questions
Basically I'm looking to build Simple Desktop (CPU only) that will allow me to browse the net, watch stuff online and to online classes etc.. (No gaming)
- What is your budget?
- 22K -The less the better but I can go up to 25K
- None
- Monitor
- Keyboard
- Mouse
- No shortlist yet
- GPU ( something like a 1660Ti ) if the above budget allows for this , Else not required
- Bangalore
- Open to online purchase
- Yes
- Browsing
- Desktop Processing
- Online education
- None
- No
- 1920X1080
- Not really
- Windows 10 64 bit
