Hello there. What will be a perfect way to monitor uptime of my JioFiber Connection?
T TinTinSnowy Adept Aug 1, 2021 #1 Hello there. What will be a perfect way to monitor uptime of my JioFiber Connection?
D D C Adept Aug 1, 2021 #2 1. My isp portal has session logs, connect/disconnect time, session duration, ip adress and data used. 2. Using smokeping in docker on raspberry pi, it pings set servers at 5 min intervals, so that I can find out if it's my isp issue or website issue The Raspberry Pi Thread @ReVo_007 I see you have mentioned that you have used rutorrent on Rpi. Can you suggest how to install and also if I can make autodl-irssi work with rutorrent? techenclave.com 3. http://www.jeffgeerling.com/blog/2021/monitor-your-internet-raspberry-pi
