FS: Cabinets [Brand New] Cooler Master Addressable RGB LED controller - compatible with all MoBo
NoMansLand
Feedback: 14 / 0 / 0
Bangalore
Packed Brand New
  1. Cash
  2. Bank Transfer
Excluded - at actuals
24 months
Yes
Not Needed
Compatible with MSI, Gigabyte, Asus, Asrock mobos proprietary RGB software
If mobo doesn't have RGB (12 V) / A-RGB (5 V) connectors then you can connect your cabinet reset switch to it and use the built-in presets
Can connect 4 A-RGB (4-1 pin) devices directly and connect even more if you use A-RGB splitter
Also, it has a temperature sensor that can change the color theme of your A-RGB devices to reflect your system temps
I ordered one from amazon but I did not as the A-RGB presets through my mobo or the device itself. My cabinet has an A-RGB controller within which I feel has better A-RGB presets.
So I placed a request for a return but only replacement was available. I got a new piece which I opened up to check if all wires are there and to take a pic to post here. It is brand new and unused.
