WTB Cabinet preferably widowed or similar with enough room to add 4 fans A mechanical keyboard, 128gb or 256gb class 10 memory card with invoice
JMak
Feedback: 13 / 0 / 0
Just assembled a new build
Looking for a good cabinet corsair or cooler master or similar for the build.
Windowed preferably.
With enough space for ventilation and option to add multiple exhaust fans 120mm, if already fitted then would be nice.
Enough options for multiple 3.5, 2.5 hdds, Enough slots for optical drives, multiple usb ports etc
Also looking for a good used a mechanical keyboard if anyone is willing to sell.
Looking for a 128gb or 256gb class 10 memory card with proper invoice.
My location is Delhi
Budget lets see the goods first.
Thanks
HereComesArya
New Member
Recruit
Feedback: 0 / 0 / 0
Hey, I have a Deepcool Mattrexx 55 Mesh with 4 pre-installed fans that I bought about 3 weeks ago. The only problem with it is that the Fan RGB does not work but you can replace them. Are you interested?
JMak
@Sammy22 has shared tracking info
Waiting for the pickup which might be done on monday
JMak
Seller has updates that the item was picked up yesterday itself
Will update
