mediahome.in
Cooler Master Led Fans - Red , Blue , Green - 90 CFM 19DBA - High Speed Low Noise
Dimension (W / H / D) 120 x 120 x 25 mm
Current (Ampere) 0.35A ± 10%
Speed (R.P.M.) 2000 RPM
Air Flow (CFM) 90 CFM
Air pressure (mmH2O) 3.04 mm H2O
Fan Noise Level (dB-A) 19 dBA
Weight 116g
Bearing Type Long Life Sleeve
Fan Life Expectancy 50,000 hrs
Connector 3 Pin
Screws 4 pcs
3 to 4 pin Adapter 1 pcs
Rated Voltage 12 VDC
Power consumption 4.2W ± 10%
LED Color Green - Blue - Red
Price : 450 + shipping
Weight 116g
Connector 3 Pin
Screws 4 pcs
