quan chi
Guide
hi,
guys i have gigabyte g31m-e2sl mobo.I was using p4 3.0ghz ht before.now i upgraded to c2d e7500.
Now the problem is the system boots properly.but whenever i try to run 'speedfan' to see the temperature the system goes haywire with blue screen flickering and then all black no response. Even the manual restart and on off buttons dosen't responds.
sometimes it also behaves like the old p4 i mean slow response.
From bios i found out the idle temp of the cpu is around 40-43 deg c.Is it normal.what is the problem why cant i run speed fan please help.
