aKp1
Hey Grey Matters!
I am on a budget rig! with a G3258 @ 4.0GHz
Previously I had an open cabinet! Recently due to dust and other problems, I shifted the setup to a Circle CT 821 Cabinet! The Cabinet is good with 2 front 120mm fans and a rear! There is space for 2 more on the top! But right now it's empty!
P.S - In no way I could manage the cables!
Previously on the open rig, the temps of the Pentium never went more than 65degrees!
But recently if ever the core reaches 100%, there is this sudden bump of temperature to around 70 degrees!
I know I have to reduce the voltages! That I'll be doing for sure!
My questions is now, whether I've to add those two additional Case fans at the top to bring down the temperatures because as you can see in the pic, it is directly above the CPU!
Or else I opt for a CPU cooler fan?
The stock does a good job though! It generally keeps the temperature below 60 degrees even when gaming or on medium loads!
But these sudden bumps are making me uneasy!
The rig is year old!
It's
CM Thunder 450W PSU
Gigabyte GA B85M-DS3H-A
Asus Strix GTX960
Hynix 4gbx1 DDR3
It's
CM Thunder 450W PSU
Asus Strix GTX960
Hynix 4gbx1 DDR3
