Delta 92x25mm FFB0912SH Super High Speed Fan
puns
Staff member
Super Mod
Feedback: 17 / 0 / 0
BUMP , price dropped to 650.
its a 90 cfm fan, ideal for those with fan controller :)
amritsingh87
Feedback: 9 / 0 / 0
will buy if i can connect it to the 4 pin plug (the one powering cdroms ) i dont know its name , is there a converter , what do i do if i want it to run at full speed all the time
puns
Staff member
Super Mod
amritsingh87 , you would need a 3 pin to 4 pin molex connector. if you want to run it at full speed , you can connect it to the 3 pin on the motherboard.
rrcraghu , pm replied to.
puns
Staff member
Super Mod
Rivunited said:
hey i want to buy it. gimme ur contact number and ur address ill try to come pick it up by tomorrow.
u have pm and my details :)
on hold for Rivunited.
