Need front USB 3.0 port.
No physical damage. There should be no issue with internal wires, switches and buttons.
Should have at least two chassis fans and the fans should be clean.
Etc.
I have an Antec GX700 that I want to get rid off for the right price. It has 2x USB3.0 ports & 2xUSB.2.0 ports all the buttons & everything is working perfectly. It also has two fans, 2*140mm & 1*120mm out of which blade of one 140mm fan got broken a while back & has been stuck back on using adhesive. It has been working fine since, but does wobble a bit & creates a bit of noise at startup. There is also a fan controller which also works absolutely fine. This is an old case around 5 years or so... so it looks the part. Fans are relatively clean but have accumulated dust on the inner side. Let me know if interested.
