Aliexpress but now its only a memorable history for Indians... You can still source it from ebay US/UK if you can are willing to pay that hefty duty thing..My friend requires a single replacement fan of sapphire Rx 470 dual fan model. can't find anywhere in india. gpu gets quite hot when he plays games.
if anyone knows where to find then let me know.
nahi mila to karna padega kuch aisa hikis k dead gpu se uthalo or just use some pwm case fan and use cable tie rubber band whatever floats the boat
zip tie a 80 mm or 120mm fan on to the gpu heatsink and connect it to molex connector of PSU so that it runs at full speed. you can also remove the dead fan and take to your electrical shop, they might be able to make it work. mostly it will require some servicing or bearing replacementMy friend requires a single replacement fan of sapphire Rx 470 dual fan model. can't find anywhere in india. gpu gets quite hot when he plays games.
will explore the repairing thing also......attaching an 80/120mm fan is the last resortzip tie a 80 mm or 120mm fan on to the gpu heatsink and connect it to molex connector of PSU so that it runs at full speed. you can also remove the dead fan and take to your electrical shop, they might be able to make it work. mostly it will require some servicing or bearing replacement
remove the whole shroud and other fan as well and replace both fans , it would work better than original noctuas are my choicewill explore the repairing thing also......attaching an 80/120mm fan is the last resort
ho much does replacement fans cost?remove the whole shroud and other fan as well and replace both fans , it would work better than original noctuas are my choice
