NeViLLe
Selling this on behalf of a friend... who has upgraded to 22" LCD monitor. The LCD was bought in March 2008 from Prime ABGB.
Looking for a quick local sale... (Mumbai Only )
Viewsonic VA1926W 19-inch LCD monitor Features
* 19-inch (40.8 cm) Color TFT Active Matrix LCD, Widescreen WSXGA, 16.2 million colors
* 1440 × 900 pixels native resolution (WSXGA+) at 60 Hz
* 16:10 Widescreen Aspect Ratio
* 5ms Response Time
* Display Area: 40.8 cm Horizontal, 25.5 cm Vertical, 48.3 cm Diagonal
* Anti-glare screen
* Dot pitch - 0.283 mm
* Brightness - 300 cd/m2
* Contrast Ratio - 700:1
* Dynamic Contrast Ratio : upto 2000:1
* Dynamic Color Booster
* Digital DVI-D Video Input, HDCP enabled, TMDS, 100 ohm, DDC/CI
* Viewing Angle - 150 degree horizontal, 140 degree vertical
* Tilt (down/ up) - 5 / 20 degree
* Swivel ( left/right) - 180 degree Height (72mm)
* Input Video - D-sub 15-pin connector
* Horizontal Refresh Rate - 31 kHz - 81 kHz
* Vertical Refresh Rate - 55 Hz - 76 Hz
* Video Bandwidth - 25 MHz - 135 MHz
* Maximum Refresh Rate - 75 Hz
* Power Management - TCO’03 and ENERGY STAR standards
* Wall Mount, VESA FDMI 100mm x 100mm
* Power Consumption - 32W (max), 1W in Sleep Mode
* Dimensions (W×H×D) 440 x 383 x 195 mm (with Stand)
* Weight - 4.1 Kgs
* 5ms Response Time
* Anti-glare screen
* Weight - 4.1 Kgs
