FS: Antec True Power 2.0 480W (TP2) Power Supply
thelord
Feedback: 5 / 0 / 0
Hi everyone.
Selling my Antec True Power 2.0 480W power supply.
Rock solid! SLI Ready. Bought it for around 5k in June 06, so it still has about 5-6 months of warranty left.
(Not used from Aug 07 to Feb 08 as I was away on training, and its lying packed since Nov 08 after I got a new PSU :) )
Technical Specs
+5V - 38A
+12V1 - 18A
+12V2 - 18A
+3.3V - 30A
Total load 480W
In Pics
Features:
* Single 120mm low noise fan
* Dual 12V outputs, for stability and safety
* True Spec noise level of 21.3 dBA measured at an independent lab using ISO 7779 standard
* ATX12V 2.01 compliant. 24-pin main power connector with detachable 4-pin section for universal motherboard compatibility
* 4 Serial ATA connectors
* Two PCI Express graphic card power connectors
* Dedicated output for more stability and less ripple noise
* Feedback circuits for tighter load regulation (±3%) to maintain accurate voltage to all components
* Industrial-grade protection circuitry prevents damage resulting from short circuits, power overloads, * excessive current, excessive voltage, excessive temperatures
* Fan only power connectors allow True Power to control case fan speeds, reducing total system noise
* MTBF: 80,000 hours
* Safety approval: CB, CE, DEMKO, FCC Class B, FIMKO, EMKO, UL, VDE, TUV
* Active Power Factor Correction (PFC)
* Power Factor value greater than 90%
* Gold plated connectors for superior conductivity
P.S.
All India warranty, bought from Amarbir (Lynx Computers).
If anyone wants, I can get a thorough clean up done for the power supply for an additional 100 bucks.
obama
Feedback: 3 / 0 / 0
Received the psu.
Will test it later and pm you the feedback.
You may close this Thread.
Edit: if possible kindly email me a scanned copy of the bill, or pm me the billing details for my future reference.
