Forum Feedback 'Go Advanced' in Editing Mode Does not work
madnav
Inactive
Forerunner
'Go Advanced' while in Editing Mode is not working since a few days for me.
It is the case with everybody?
NinByChoice said:
Works fine here. What skin and browser? Tried clearing cache/cookies, re-login?
:ashamed:
i never considered re-login as an option since i never logout :P
update: It worked for once and back to same problem.
Even not working for me. I'm on FF4.0 with Adblock Plus 1.3.3.
Here is the workaround: Double click on edit post to go to advanced editor.
The problem is temporarily fixed for a long time now..
It gets you to advance mode directly without choosing to when you hit 'edit' for the 1st time.
if you try to edit again later for the same post then you are back to the original issue.
