Good quality Display Port to mini Display Port cables/convertors?
Stronk
Hi all,
Kindly suggest a good mini DP to DP cable, or a mini DP to DP convertor for the purpose of using a laptop's mini DP port to connect to a monitor. I already have a Display Port cable so if it would be possible to get a DP to mini DP convertor (if they exist) I would much prefer that. Otherwise a mini DP to DP cable of at least 1.5ft in length will do, preferably under 1000 bucks, although not a strict constraint. Thanks.
rsaeon
Adapters like these were originally bundled with the Radeon 6950, I could send one over to you if you think they'd work.
Stronk
That looks cool, will pm. Thanks a ton!
I use an AmazonBasics mini DP to DP cable and it works well.
Want to avoid amazon basics because i've had pretty bad experience with their mDP cables. Somehow I got 2 bad cables back to back from them, so wish to try another brand.
I've always had good experience with Amazon basics when it comes to wires. You can try this if you don't want that one, Dell should be solid.
Stronk
Titokhan
I was looking for a Mini DP to HDMI adapter for my father as he wanted to use a bigger screen alongside his MacBook Air 2017. Since I wanted to repurpose one of the several HDMI cables in my possession, I pinged @tommy_vercetti after seeing his post.
To my surprise, he literally gave it away! Even during the harsh Mumbai monsoon, he managed to courier it to my hometown in West Bengal. Words are really not enough to express my gratitude, but here we go: thanks a lot!
