DavyJones
hi guys,
Recently i encountered a problem. Before describing the problem i will state my system config. i5 2500, DH67CL, 8GB RAM (4GB x 2), MSI GTX 550 Ti, 500GB HDD, Corsair CX430, APC 650VA UPS.
So my problem started while i was playing a high end video game, suddenly my power went off and strangely my apc 650va ups couldn't handle the full load and it shuts down for 1 sec ( battery charge was 100% at that time ) . my system shuts down as a result of that. when i tried to start the system after that it start to beep 3 times then shuts down again (the complete process took 3 secs ). According to the beep codes of my mobo, 3 beeps = memory failure. So i took the 2 memory sticks out and then tried both of them one at a time on all the 4 memory slots. still the same beep sound occurs. I tried to check the psu by only connecting one fan and then shorting the green & black cable of the 24pin connector. psu fan & the external fan runs without any problem.
Then after two days i tried to start the system and it worked flawlessly. but being a nutcase
i again started playing games and again power went off & again my apc couldn't handle the load. Now when i try to start the system it shows the same problem. 3 beeps & shuts down.
I don't know why my APC 650VA ups failed to handle the full load.I spent 3000 rs on ups to avoid such problem. I know i need to replace the UPS. but i'm confused about my system. I still can't figure out which part of my system needs to be replaced? . Is it my mobo or my psu or my cpu. I don't think the prob lies in the memory sticks b'coz two sticks can't stop working at the same time. What you guys think???
