shashank_r_t
Hi All,
Today I got additional 2 x 1 GB sticks (Transcend Jetram) and hence have upgraded from 2 to 4 GB ram.
However I am facing issues booting up the machine if all the 4 sticks are loaded.
Sometimes the PC just doesnt boot.. and if it even boots it does not pass the bios loading stage (OS starts loading and hangs)
Following things I have tried:
1. Tried with the new only and old only sticks (Both winxp and Vista 32 bit work fine)
2. Tested all the 4 slots.. both MOBO and Rams does not seem to have any issues..
I suspect it may be the PSU.. as when I disconnected the extras cabinet fans.. the pc atleast started. (If i connect fans then it does not even boot with 4 sticks.. but works fine with 2 sticks)
If 4 sticks are loaded.. OS gives errors like NTLDR missing or Winload.exe missing..
Any suggestions?? Following is the config..
E6750 @ stock (2.66GHz)
4x1GB Transcend Jet Ram (667 mhz - All are similar model and same frequency)
ASUS P5B
80Gb Seagate HDD
250Gb Western Digital HDD
4 system fans
Palit 7600 GT
Sony DRU 820 DVD writer and Samsung DVD ROM
Pinnacle Tv Tuner 110i (internal)
Thanks...
Shashank
ASUS P5B
80Gb Seagate HDD
4 system fans
Palit 7600 GT
Thanks...
Shashank
