neomustdie
- What is your budget?
- 20-30K
- CPU - AMD 5100
- Motherboard - Gigabyte 785GMT USB3
- GPU - ATI HD7770
- RAM - 8GB
- Monitor - Dell 24 somthing.. no Vesa mount
- PSU - Corsair VX450
- (please mention the rest in above format)
- Monitor, PSU, ODD, 5.25 inch 1TB HDD, RAM
- CPU - Intel quad core preferably i5
- Motherboard - mini iTX with front USB 3 header + back USB3, WIFI
- Cabinet - small cabinet which can use my regular Corsair VX450, HD7770, the ODD, HDD and 128 GB SSD for boot drive. Cabinet as small as possible
- Media Center compatible remote
- No, my last desktop upgrade.
- Mumbai
- Open to online purchase
- No
- Mainly Photoshop, Fireworks and Eclipse usage
- Browsing (a lot)
- HTPC, moderate gaming
- Rarely (read once a week) Download rig, 24x7 operation
- Watching HD movies (a lot)
- Not going for AMD as it is not hakintosh compatible
- Mostly FPS like COD and sports like FIFA. Have Xbox controller for windows for playing
- Gaming - 1440x900 to Full HD
- Desktop - Full HD
- No
- Have Win 8.1 Pro
- Will use Linux ubuntu (virtual machine)
I want a moderately powerful machine to suit my work needs and let me enjoy some games. Space is a big constrain and hence want small cabinet. I don't want to go absolute compact as i want to reuse my GFX card and PSU. Something like Coolermaster Elite 120/130.
Front USB 3 is a must. Smooth Photoshop for designing and Eclipse/VS for coding.
Please suggest. Want to purchase in a week.
