Silent Shout
Hello
GOAL:I am building a Dual Monitor (same size and same brand? 24inch/more) with single/dual GPU setup(dual GPU only if necessary)
I want to use SSD (indilinx/barefoot any good controller) on RAID 0
USB 3 and SATA 6Gbps and onboard RAID.onboard wifi N
This system/server will also run 2 PCI/ PCIe based realtime DVR compression(one D1 and other 1/2 D1) cards for CCTV. It will use H.264 compression and dedicated HDD space. Dahua/Hikvision
Card 1 Zhejiang Dahua Technology Co., Ltd.
Card 2 Zhejiang Dahua Technology Co., Ltd.
The system will also function as pentaplex CCTV system where remote viewing is possible.
So sytem will be connected to Broadband Bonding Network Appliance Mushroom Networks, Inc.
It will also be connected to presently one and in the future two Full HD LCD tvs for CCTV monitoring.
Fast Data encryption and Decryption capability.
I will also need this system(Server) to run a custom software solution with 4 client machines on LAN feeding data to it. Data will only be stored on Server and not on client and only admin can modify data.I will also attach multiple currently (3) biometric Time & attendance Recorder with Access Control machines via LAN. NITGEN & COMPANY
It will also run acess manager software.
NITGEN & COMPANY
It will also serve as one way SMS Gateway as I will be attaching a GSM modem to it.
It will act as web server when bandwidth gets cheaper.![Stick Out Tongue :p :p](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
So system has to be reliable.
Presently I am going to use it at home and will put it in office after 2 months. I am planning to run this as Linux based box.
Secondary use : Browsing, Desktop Processing, HTPCDownload rig(only if extra bandwidth available , 24x7 operation Watching HD movies(sometimes)
Q: What is the purpose of dual monitor system : Spanning as well as mirroring extended desktop
Desktop productivity and research on BOTH monitors or watching 1080p movie on second while working.
I have a lot of data open(multitasking) so want Fast RAM and a good SSD for quick browsing through 100s of TABs(chrome and FF), 10s of open PDF files,word files,excel spreadshit, accounting software, you tube videos ON 1 Display while doing similar stuff, or watching 1080p rip ON SECOND Display.
Q:Budget:
100K
My Current Setup: Processor intel Q 6600 2.4Ghz / .MB .Asus P5k deluxe(P35) / RAM 2X2GB DDR II 667 Transcend /GPU Nvidia 7900 GS / HDD 640GB WD Green X 2 / Display single monitor Acer AL2216W /PSU Antec neopower HE 500/ O.S. win XP
(I have about 30-60% CPU utilization most of the time with upto 6 GB pagefile used :S)
Q:Requirements: I have an OPEN MIND
Processor for Multitasking and multi threading
corei7 or Phenom II good OC but basically should run fast on stock.
M/B OC capablewith USB 3 SATA 6 Gbps RAID and good OCing and if possible Wifi N and bluetooth (optional) minimum 6 SATA ports( Two LAN ports optional)
CPU cooler: would prefer liquid cooling for both CPU and GPU else good air CPU cooler , (if feasible fanless dustfree liquid cooling solution optional)
I want to keep this expensive machinery in lock with limited ventilation so i want a system that doesn't heat up too much.
RAM 12 GB -16 GB tight timings and reliable pls suggest a compatible RAM DDR III triple/dual channel
GPU:single/double(crossfire/sli) you suggest, No gaming so whatever supports DUAL DVI/HDMI setup in leftover budget will do. ATI/Nvidia with Double 1080p H264 playback on two monitors. Would prefer Eyefinity based card with support for 4 HD devices.
HDD: SSD X 2 in RAID 0(size depends on budget) should run OS and about 60GB softwares , will use 2X640GB WD green from old PC as back up drives. And add 2X 2TB WD black later date.
Cabinet: Any Non gaudy quiet no LED please as far as possible (or option to switch them off)
Monitor: 2X24 inches or more in size full HD LCD/LED same make, resolution should be good for viewing HD movies
PSU: Please suggest a suitable one modular or non. Considering all the req.
Optical Drive: old LG PATA DVD RW / new SATA DVD RW
Mouse KB: old wireless iball laser
Q: Final configuration?
No will add more 2 SSD as prices drop and increase RAID array and 2 LCD TVs and 2XWD black 2TB
Option 1 : IBM/Dell ( if they have what I need for good price)
option 2: Custom system Mumbai Lamington road from a dealer who will assemble the product ensuring compatibility and will provide good A.S.S as well as OC the system, :hap2:
Purchase from TE dealer subject to costing and Reliability and A.S.S. (Mumbai based only)
Q:Gaming
Rare gaming(almost never). No graphics editing either. But as I am going to attach 2 HD monitors and one or two LCD TVs I might require a decent GPU.
Q:OC?
Overclock only if I get 100% stable system.Stability important.
Q:OS?
Linux (i want TRIM support on RAID 0+1) Software based (unless new RAID controllers support it HW)
OS windows 7(for trimming- SSD) I will use ultramon software on RAID 0
Q
referred monitor resolution?
Full HD/native on Both
Thanks for reading now Please Reply
suggestions welcome pls give me options.
ty
EDIT : Finally added all requirements. Please help me to build this complex system.
NITGEN & COMPANY
Q:Budget:
100K
Q:Gaming
Q:OC?
Q:OS?
Q
ty
