HELP : PPPoe better than Bridge connection?
ComradE_BeaN
Inactive
Explorer
Is PPPoE better than bridge mode ..?/..cause today i changed the modem settings from pppoe to bridged .. & after setting up everything ... i noticed the pings to the sgservers were up by ~12:rolleyes: , & the pings to primary & sec dns were also higher...:huh:
any explanation would be helpful...
i can post the pics if necessary .. but then i would have to require to do the same steps again....:no:
p.s:,,,the ip address were almost similar 59.@.@.@ both the times...& i think that shoudnt be that different..
Any help to sort this would be extremely helpful..
I prefer bridged + a good firewall (or simple common sense).
pppoe is more secure but unless your router supports upnp, port forwarding is a frequent annoyance.
The 12ms difference could simply be by chance.
I also have heard that bridged does make some difference although haven't tried it. Also my router doesn't support unpnp it seems, so do port forward manually :(
when in bridge mode .. i reconnected several times (to get different IPs')
all the times it was having higher latency....
saiyan,
wht router, what ISP & where are u located (from the exchange as well as relatively where in India) would make lots of difference. Although my router has bridge mode but 've never used it.
my modem : beetel 220bx
my isp : Airtel
the areas' router is located ~200m from my modem :)
anyway i tried bridge mode to automate the download....thats all..
