A strange issue has been happening for some time with my CPU. I have an Core i7 860 CPU running with its default cooler. My CPU temp randomly jumps up to 99 degrees (TJ Max) and causes the system to shut down. I have no idea why this is happening. There is no particular task that causes this- I may be browsing or playing a game or working on a Word document. It is just random with absolutely no pattern.
The only hardware change that I did recently was change the power supply. I'm unsure if it could be causing this issue.
Any thoughts, suggestions, troubleshooting steps in resolving this issue would be most helpful.
Thanks
Thanks
