vinayaga
Folks,
Im looking to replace my aged Onkyo 5.1 receiver that does not take HDMI and seems to have issues decoding some of the newer digital audio streams send by the WDTV. To be frank, I have not done much research in shops for newer receivers, but Im sure the guru's in TE will let me make a choice.
Please suggest some basic receivers for less than 20k. Should have HDMI inputs and passthrough, 5.1 is enough and atleast two optical inputs.
Also with regards to ebay global, any idea if the prices are good in India ?
Global Easy Buy
Global Easy Buy
Global Easy Buy
Global Easy Buy
Global Easy Buy
Global Easy Buy
