Search
Search titles only
By:
Search titles only
By:
Forums
New posts
Search forums
What's new
New posts
Latest activity
Feedback
View Statistics
Members
Current visitors
Buy Sell Trade
WTB
Log in
Register
Search
Search titles only
By:
Search titles only
By:
New posts
Search forums
Menu
Install the app
Install
Reply to thread
Forums
Need Buying Help?
Gadgets & Consumer Electronics Buying Advice
Help with Netflix and 4k 65 inch tv please?
You should upgrade or use an
alternative browser
Message
<blockquote data-quote="rdst_1" data-source="post: 2318834" data-attributes="member: 25986"><p>The thing is that LG/Samsung/Sony charge a whole lot for the jump from 55 to 65 inch. And it is still their entry level TV. At 80k - 1L range, one then gets the option to get a better TV although in 55 inch size. If the increase in size is more important to you than the PQ, then you can go ahead and buy the UP7500. Try and see if your local retailer will match the online price and that way you can check whether you are getting a VA panel or an IPS (if they allow).</p></blockquote><p></p>
[QUOTE="rdst_1, post: 2318834, member: 25986"] The thing is that LG/Samsung/Sony charge a whole lot for the jump from 55 to 65 inch. And it is still their entry level TV. At 80k - 1L range, one then gets the option to get a better TV although in 55 inch size. If the increase in size is more important to you than the PQ, then you can go ahead and buy the UP7500. Try and see if your local retailer will match the online price and that way you can check whether you are getting a VA panel or an IPS (if they allow). [/QUOTE]
Insert quotes…
Verification
Post reply
Forums
Need Buying Help?
Bottom
