- What is your budget?
- 5K or fair market price for PSU
- As cheap as possible for an ATX case with space for 4 or more 2.5/3.5 inch HDDs
- Fair price for case fans
- CPU – AMD Ryzen 5 2600
- Motherboard – MSI X370 GAMING PLUS TITANIUM (ATX)
- GPU – Zotac GTX 1060 mini (6GB)
- RAM – G.Skill Ripjaws DDR4-2666 2*8GB kit (might OC to 2933MHz or higher)
- SSD – 256GB NVME SSD for OS/Boot drive
- HDD – 16TB Seagate Exos SATA 7.2k RPM (planning to shuck, brand new from Amazon)
- PSU – Looking to buy this (Gigabyte P650B 650W 80+ bronze from Amazon)
- Case - This or this [Corsair Spec-01 or Carbide 100R ATX case, prefer 4 or more 3.5 inch HDD slots, as cheap as possible]
- Thinking of buying this (4*120 mm *cheap* fans from Cooler master). I don't know if it's sufficient or is of good-enough quality. Request suggestions on case fan configuration as well. (Thinking of 1 inlet each from front and top, 1 front inlet for HDD bay and 1 back exhaust)
- Prefer online purchase or TE Dealer
- Hyderabad (as last resort)
- Yes. Would prefer brand new or like new though.
- Primarily for Plex/media streaming server
- Occasional Gaming
- I don't game a lot but I want to play upcoming games like Watch Dogs: Legion, Far Cry 6, Cyberpunk 2077 (my specs are probably a joke)
- War games like World of Tanks (PC) and World of Warships (PC) and War Thunder
- Maybe but I don’t have any plans currently.
- Windows 10 Pro 64 bit
- Linux – Ubuntu or Manjaro 64 bit
