Hello everyone!
I'm a new member and happy to be part of such an awesome community! Im looking get a new rig for FX/Animation work. I have listed out my Requirements below and am sure you can help me choose the best option. I would also like to add that your advice and suggestions are much appreciated. So, lets get to it then.
Q: What is your budget?
50k-55k
CPU - amd phenom 9850
GPU - ATI FireG V5600
Monitor -dell st2210
Monitor - dell st2210
CPU - Intel Core i7-3770K Ivy Bridge 3.5GHz Intel HD Graphics 4000
Motherboard -ASRock Z77 Extreme4 Motherboard OR any compatible motherboard
RAM - G.Skill Ripjaws DDR3 32 GB PC RAM (4 x 8 GB )
HDD - 1 Tb seagate/WD( Need Suggestions.)
SMPS - Need suggestions.
CABINET - 2k max. Good cooling and relatively noise free.
Yes, will upgrade the following within 6 months
GPU - NVIDIA Quadro FX 2000 PCI 1GB
Bangalore.
No
Vfx/ Animation and Rendering
Watching HD movies
Desktop - 1920 X 1080
No
Windows 7 64 bit
50k-55k
Bangalore.
No
Watching HD movies
No
Windows 7 64 bit
