set top box have composite output....so how can i connect it to lcd monitor which has dvi........
K kumar007 Disciple May 30, 2009 #1 set top box have composite output....so how can i connect it to lcd monitor which has dvi........
axeman Ye Olde Systems Breaker Skilled May 30, 2009 #2 if u mean lcd TV then it has composite input, if u mean lcd pc monitor, then sadly u will need to invest either in a expensive convertor or a tv tuner for the pc which has composite input and then outputs via gfx card to lcd
