PC Peripherals Just bought 4 120mm cabinet fans, need help with a cable.
zibalingz
Forerunner
Hello everyone,
I just bought this 4 pack of 120mm coolermaster cab fans for 760 bucks on flipkart, but they all have 3 pin connectors
http://www.flipkart.com/cooler-mast...=b_5&ref=b1bad206-ec31-4339-8011-c2679d452067
and I need a particular cable like below to connect all the fans since there are only 2 3-pin connections on the mobo.
http://www.amazon.com/Phobya-4-Pin-Molex-Connector-Connection/dp/B004CLDSRU
Now I cant seem to find it online anywhere in India, Ebay and Amazon have it but it not available locally
Anyone know where I can procure such a cable in Mumbai? would really appreciate it :)
Thanks!
try local computer shops they will be having these converter cables. As you are from Mumbai searching at lamington road may get these cables. I bought same pack 2yrs back and got the connectors at local shop in S.P.road Bangalore.
