raksrules
Elite
So i have this MSI netbook which i have kept ON 24/7 at home and connected to internet. The problem is that in my area, sometimes there is load shedding so the electricity is not available for couple of hours or sometimes extended period like 5-6 Hours. Now this usually happens when i am not at home so if there is no electricity for few hours then there is a risk of laptop shutting down.
Now one thing that can prevent this from happening is the brightness, if that is kept to minimum then the battery will keep the laptop on for longer time.
Coming to the problem, the laptop has hardware brightness control keys (Fn+ down and up arrows) and that is how I control brightness. I always keep it to lowest setting even when electricity is there.
But if by some reason the electricity is cut off or i shut off the power to laptop, its screen brightness changes to maximum. Now if i even resume the power, the brightness still remains at maximum. So this will eat more battery when mains are not available. I do not want the brightness to change irrespective of whether it is on battery or mains power, i want it minimum always.
Any way to fix this ?
I am using MSI 14" Screen netbook with windows XP installed, if that helps.
