Laptop SSD Upgrade Strange Problem
jatin1931
Recruit
Hi,
I have upgraded my old laptop with Crucial BX500 240 Gb SSD and facing a strange problem. The system hangs on restart / shutdown (i.e. at the time of installation of windows 10, normal shut down etc.) every time. The system becomes non responsive, but the CPU fans started rotating faster. The problem occured only after installing the SSD. Could the SSD be the problem? Could it be not compatible? Any solution?
Thanks
RadarHz
Did the installation happen successfully, or does the problem occur even during the restart in the installation process?
jatin1931
Recruit
Yes the problem occured each time the system is shut down or restart.. i.e. after installation is completed; after final steps is completed or after normal shutdown or restart..
jatin1931
Recruit
Don't install old OS. Run some tests on SSD. If no use then get replacement. Try to get a Samsung SSD.
Which test to run on SSD??
Quick Test Fails.. Will get the SSD replaced. Should I go for Samsung or Crucial is also reliable under SSD. Price difference is double.
booo
BA BA BA BABANANA
Use smartmontools or crystal disk info to read smart data and see if any errors show up.
Rockfella
Nitrate killer!
Staff member
Patron
Yep. Crucial is good too. Samsung is true king of SSDs. Your call :). Get any but test the ssd asap when you get it.
mr_mcfly
Any chance you're using a caddy or perhaps have a SATA - 2 interface?
Some caddies have a switch that changes the mode of your interface and cause hangups.
frozenscotch
Do get it replaced immediately, seems like you got damaged goods.
Go for Crucial MX500/WD Blue series, or get Samsung SSD
