LED monitor @10k
Tech Savy
Guys suggest me a decent 22-23'' LED monitor with HDMI port. @ 10k.
Uses : Gaming @ HD with pair it 6870.
Should not have bleeding issues. .
Guys going to buy LG E2360V @ 10k for my friend. Any reviews?
One query :
my friend wana watch TV on it thru cable wire not DTH. So what should be done?
At that budget LG LEDs will be good, or try BenQ...
Also if u can increase ur budget to 14k get Dell U2311H, which is an IPS Panel, way better than TN ones.
I dont think that LG model can be used as TV(cable), u can use DTH HD connection though with that...
Hope this helped...Any more queries let me know...
I have an Acer H225HQL. 22inch FHD and LED monitor. colors are damn good, has vga, dvi and hdmi.
I have Dell ST2220M...Colour reproduction is pretty fine.. a slight bleeding on the left side of the screen but nothing major i reckon..
I can vouch it over a Dell p2210 cause that's what i got as an replacement under Dell exchange through warranty..
Not the Dells fault it went Kaput it is just that the Dvi port got fried cause of lightning:eek:hyeah:
Even the motherboard got fried but the DELL went on and on on VGA!!! That should say something about its reliability :hap2:
Ther is an HDMI version its ST2220L price should hover around 8.5 k.
Honestly best bang for the buck :)
